HELP! Mechanical boost only - mostly!?
  • madpugger
    • Sep 2007
    • 1901
    Originally posted by prj
    It's not faulty.
    Just the checksum doesn't match, it doesn't mean it's faulty.
    It's possible it has been there all along.
    The checksum in the boost chip is a bit harder to correct than the fuel chip, but if it's MRC they know how to do it
    Also, a bad checksum will have absolutely zero effect on your car besides throwing that fault. Zero, zilch, nada.
    It's the G40 and G71 errors that you have to get rid of for it to boost again! Those can't be caused by bad mapping either.
    Maybe badly soldered MAP sensor or a leak, or bad contact to the sensor.
    OK, well it only had the checksum code with my other ECU as far as I remember, no other codes... However it has been a while, so not 100% sure.
    Le Mans 2012
    Nurburgring 700
    1995 S2 Avant
    • madpugger
      • Sep 2007
      • 1901
      Originally posted by ericd
      can you get to the meeting (Famous Grouse) at the end of the month with the car
      I havent seen the dates, but if it is after the 22nd then yes
      Le Mans 2012
      Nurburgring 700
      1995 S2 Avant
      • prj
        • Mar 2010
        • 6308
        But if I remember correctly you swapped the fuel chip to the other ECU and left the boost chip in place, and it still didn't boost on the same car?
        There must be other errors cropping up as well.
        When the ECU is not boosting, it will always tell you why.
        But since you have not leak tested it, it's also possible something burst somewhere.
        • madpugger
          • Sep 2007
          • 1901
          Yes I think thats what we did...
          I will get it leak tested as soon as i can find the time.
          Le Mans 2012
          Nurburgring 700
          1995 S2 Avant
          • ericd
            • Nov 2003
            • 1240
            sunday 27th march stick your name down and bring the car
            • ericd
              • Nov 2003
              • 1240
              It's not faulty.
              gee us peace it's either a 1 or a 0, it's not quantum architecture
