What should be used to install oil spray jets?When i had them out for cleaning oil passages they went off very hard.Now at installing they go to easy in their holes.Under their seats(where they rest on the block) there is a rounded hole.Some of them had something like a sealing compound in that chanels.I tried a small o ring but it is not seating very good there.
I guess it will not be a massive leak if they are not sealed but i want to get things right this time
Thank you
Another question:after a bearing failure did you cleaned the oil cooler and it went nice and clear?Or particles of metal still remain there and can get in the oil?Is the cooler after the oil filter or in front(i'm at home and can not ceck )
Thank you
