Wiring Masters Needed B3 90q with AAN swap
    #31
    Dont worry about it for now...
    • Durr McDanks
      • Mar 2010
      • 79
      hmmm it didnt fire and I am pretty sure its timed properly too... maybe I fouled the spark plugs
        Pull them and check/dry them. I have the feeling that they are dry and you still just don't have the wiring quite right. But hey I will be pleased to be proved wrong.
        • Durr McDanks
          • Mar 2010
          • 79
          Yeah they were pretty dry. What is wrong with the wiring still? The LED light test worked. I am not getting spark for some reason either but I am getting switched power at pin 27.
          FYI: its not the POS sensors because I have the high output kit from 034
            So now you have to establish the following:
            1. that you have power to the coils with the ignition turned to "on", white harness connectors in an AAN. You need a multi-meter set to DC Volts to do this.
            2. that you have spark during cranking (starter activated). This DIY should help:
            If you have spark, button things up and move to (3)
            3. that you have fuel at the fuel rail while the starter is engaged. Probably easiest to pull the injectors and fuel rail out of intake manifold as a unit, placing a glass jar under each of the five injectors and having somebody turn the ignition to start and see if anything comes out. I suspect not.
            • Durr McDanks
              • Mar 2010
              • 79
              1. I have power on all 5 pins but its getting 11.3 volts does it absolutely 12?
              2. I am running to the store to get the tester
              • Sleeper_Avant
                • 2372
                check and make sure it is getting 12v feed at the ECU while cranking, had this while putting the engine in my A4.
                Simple fix if it is, power gets cut from main power sources under cranking, i.e fans, radio, lights etc
                Sean.
                • Durr McDanks
                  • Mar 2010
                  • 79
                  At the ECU its still 11.3V so I went to the battery and the battery is at 11.3v. I have charged the battery for a while and its a relatively new battery and its still stuck at 11.3V. But the main question I have is is it necessary to have 12V or will a 11.3 suffice?
                    A "12 volt" DC system is rarely at 12V. As you have found, with the engine not running the battery has less than 12V (11.3V is probably fine, I doubt that is your problem). Once the car starts, the alternator will put 13.7V or so into the system so when you put the headlights and heater fan and wipers on, you will still have at least 12V (hopefully - when you engine finally is started).
                    • Durr McDanks
                      • Mar 2010
                      • 79
                      There is no spark but 11.3 volts is registering at each pin in the white connectors.
                        If you have voltage (11.3V in this case) at the white connectors, but there is no spark while you turn the key and engage the starter, then there must be an issue with the ECU *OR* the way you have the 034 HO coil packs wired to the ECU.
                          Further to the above, based on this photo from the 034 website, I don't see a separate ground for the coil packs. This means that 034 is assuming that the ground for the coil packs is made through the AAN harness, which includes one ground wire to the back corner of the cam cover and one to the intake manifold.
                          Durr, do you have these grounds in place? No grounds, no spark (the internal POSs are really switches that the ECU controls and sends power FROM the coils, through the POS (internal to the coil packs in this case) to ground in order to create the spark at the right time and for the correct length (dwell). No grounds, no spark.
                            #43
                            That's a good point. The factory loom has a big earth strap from coils to the head.
                            Would be good to know if the ECU is immo type or not as well.
                            • Durr McDanks
                              • Mar 2010
                              • 79
                              On the 034 harness there are two grounds(or what I assume are grounds) of which both are attached to the back corner of the cam cover. Where should I send my ECU to to make sure everything is working properly?
                                Are you kidding? After all this, you don't even know if the ECU is working properly? How was it in the donor car? Did it work then?
                                A good way to check if it is working is to find somebody local to you with an UrS4 or S6 and ask them if you can swap your ECU into their car to verify that it works. There is Steve Eiche in Arvada Colorado who can check your ECU if it doesn't work. (Common problem is water-damaged ECUs from failure to clean the UrS4/S6 plenum drain).
