Guys I have an issue.
On 1.2bar boost engine throw oil from "crankcase ventilation" so catch tank need to be made. Question is where I should connect the return pipe of the catch tank to avoid actually the presure form housing itself to throw oil through the return pipe as well?
Basically I need some part of the engine where presure is low so that the OIL flow back in to the engine without risk to be throw or keep in the tank?
Sorry I'm not very familiar with catch tanks so i need advice...
