Only basic boost - any ideas?
I took top cambelt cover off, need to remove a few bits to get at it. Then aligned flywheel mark and checked camwheel mark. it was 1/2 tooth out. So moved belt one tooth, so now 1/2 tooth other way. Turned engine over by hand, OK, and then rebuilt and test drove. All OK and full boost back againHow did you check the timing and realise it is 1 tuth out?THX!
Timing marks a little vague, and the weird thing is it started and ran mint, just basic boost.
A question, when you get an adjustable pulley, is the hall sensor cutout on the camshaft part or the cambelt part of the pulley?
PeteAudi RS2 Volcano Black, MRC chip, Milltek exhaustComment
I believe RS2s are always 1/2 a tooth out, quite a common thing to get it the wrong way, glad you got it sorted.Comment
Would I be right in thinking this is because the water pump pulley is a different size to a S2.I believe RS2s are always 1/2 a tooth out, quite a common thing to get it the wrong way, glad you got it sorted.
I assume the centre to centre between crank and cam is the same, ie, block and head height?
