Drain to sump
  • madpugger
    • Sep 2007
    • 1901
    Originally posted by terrybullwon
    Just a note.
    Rule of thumb you should not drop from -12An to -6 or -8 it just won't work that way
    Based on?
    I am not saying you are wrong though.
    It´s not ideal but to go from 1/4 to 3/4 there is little option! Ideally the drain would be 19mm on the tank.
    Le Mans 2012
    Nurburgring 700
    1995 S2 Avant
    • A80Avant
      • 10873
      • Country: Greece
      #77
      i didnt see any dropping to a smaller size. Its an increase we are trying to achieve
      • terrybullwon
        • Mar 2006
        • 8782
        Originally posted by madpugger
        Based on?
        What Faye at speed flow told me.
        It's more likey that the smaller dash size is a fitting on something and the -12 is the susply line. I have over a few hundred of these and spent many thousands on them. I am only trying to help.
        Have you ever had a -6 and -12 in hand?
        Chef
        • terrybullwon
          • Mar 2006
          • 8782
          In that case sorry vas I didn't read the posts correctly!
          Chef
          • madpugger
            • Sep 2007
            • 1901
            Sorry James, I wasn´t suggesting you were not trying to help, I just wandered your thinking! I work with fittings for a living, but by no means an expert!
            As Vas says, we are going up not down, but I thought you meant the reducing nipple itself was the problem, not the direction. In which case, yes, -6 to -12 is not a good way to go...
            Le Mans 2012
            Nurburgring 700
            1995 S2 Avant
            • Jonnybravo
              • Aug 2008
              • 2051
              Slightly off topic but are you breathing from the "dalek" part on the block and cam cover or somewhere else on the block ?
              • terrybullwon
                • Mar 2006
                • 8782
                What are you trying to do then mike? A fitting for the sump?
                Chef
                • madpugger
                  • Sep 2007
                  • 1901
                  Vas has a 1/4 NPT female on his catch tank, and a 19mm tube on his Fumoto valve on the sump, he wants to use the Goodridge push fit and have a tight angle on the bottom of his catch tank as it is over his Exhaust.
                  Therefore
                  1/4 npt Male elbow to jic -8 Male
                  -8 jic to -8 jic female-female
                  -8jic to -12 jic male male
                  -12 jic to push fit of 19mm
                  Hose from there to fumoto valve.
                  Le Mans 2012
                  Nurburgring 700
                  1995 S2 Avant
                  • A80Avant
                    • 10873
                    • Country: Greece
                    #84
                    Unless I can Make the 1/4 female on the tank larger in which case it get much simpler!
                    • terrybullwon
                      • Mar 2006
                      • 8782
                      Weld on a -12 male to bottom of your tank and then use a 135deg -12 fitting to keep it clear on your down pipe
                      Chef
                      • madpugger
                        • Sep 2007
                        • 1901
                        Is the ABY sump plug the same size as the ADU? Whats the thread sizes?
                        Le Mans 2012
                        Nurburgring 700
                        1995 S2 Avant
                        • A80Avant
                          • 10873
                          • Country: Greece
                          #87
                          i think so
                          thread size on the plug is M26 x 1.5
                            Got my Fumoto valve through today, super fast delivery and the mocal oil hose fits perfectly
                            Edit:- upon closer inspection, it appears that the threads on the valve have been damaged, IMO from impacts with other valves during storage or shipping. The damage appears to be light and repairable but could damage the aluminium sump threads, if fitted in its current state. While this could happen to any sump plug, I do not see that it is acceptable on a £30 new part and so have emailed them.
                            Worth checking the threads for the same damage, if you purchase one
                            • A80Avant
                              • 10873
                              • Country: Greece
                              #89
                              Mine looks spot on actually.
                              • terrybullwon
                                • Mar 2006
                                • 8782
                                Simples
                                Chef
