Sounds really cool, and iam considering buying one. And it is a Dump Valve og Blow Off Valve. But are you running stock Dump Valve?
/JOnas R.
You could use this, but to avoid problems with your mixture you would have to use THIS fitting to make it a recirculating valve and keep it a closed loop system.
Nice valve though, I do like the HKS stuff, I just bought one of their SPF air filters .
I was running a forge re-circ for a while, but it caused the car to stall all the time. So back to a standard one from VAG now. £25, can't go wrong..
Exactly why I changed mine back from a forge re-circ, car was wanting to stall evertime the revs dropped down, replaced it with a later standard one from a 225 TT/S3, problem sorted
2001 Avus Silver B5 RS4.
1995 S2 Coupe - sold (sniff)
Was it mounted the right way round? I have to have my Dahlback one mounted 'backwards' otherwise the air pushes against the side of the piston and it leaks..
Take a look here for more details and comparisons..
1996 A6 TDI Quattro Avant, Xenon HIDs, A4 Autodipping rearview.
Previous: UrS6 with RS2 bits.. <sigh>
The forge problem sounds like the valve was fitted backwards. Fitted in reverse, it works terrible! then again, it not made to go in backwards!! ;-)
I tried it both ways Martyn,,,,was pants both times,,,,,everytime I would come to a roundabout/junction and put the clutch in, the revs dropped down below normal idle (800/900 revs) and nearly stalled (never did stall though), then bounce back up above idle, then settle. Drove me bloody nuts. Bought a standard Bosch DV from my mate at local specialists who had removed it from brand new 225TT, they told me it is the same one as in the S3, which a few people on here are using, part number, 06A 145 710 N,,,No more bouncy revs
Funnily enough, I bought the Forge one to fix the exact same problem, only not as bad
