chipping and what does the chip control??
yeh but with emerald i can map it myself on my laptop, i know how it works from watchin my mate on his 205 t16 so remaps are easy and the expense has been delt withComment
It doesn't quite work like that, the ecu still needs to be mapped if you change the settings, the biggest thing is changing the ignition timing which until you've learnt about tuning is best left to the professionalsill give them a call tommorow and pick another one brain lol
its jst if i keep on tuning il may want another chip down teh line so your lookin at a £1000 worth of chips lol were as this engine management would be £813 all in for life no matter what mods got put on the car and i could also set a ecconomy setting and a max setting then have a middle setting to play with myself :-)
too many options and loads of travel required to get it sorted lol thats the worst bit,
i feel more under pressure cos id love it mapped intime for easter weekend (24th/25th april)at york drag strip to see how its running and time ticking away is making ti a tall order
Mapping is not easy, ask Audiman he's a mechanic and 4 degrees too much timing destroyed an engine on 034 ecu, you have to learn A LOT and take it slow making gradual changes.
I had my VEMS mapped purely so I could get it on the road safely on quite and expensive engine and then it easily tweaked from that point
You have a hybrid, you have no reference points so it's a brand new map setup.
For 330 bhp get it mapped and then worry about future upgrades at that point later on.Comment
cheers Jamo youve been a star, ill give MRC a call tomorrow and see were i go from their, but if they fit me in ill prob get it straight down cos i need a map now and i dont want to drag it running like ***** i dont want to kill the things its mint after al the hours gone into making it all fresh and new againComment
Facepalm !Paul Nugent
Appetite for destruction haven't you ,
put the spring in then post us the pics of your bent rods later . You have been warned !Comment
Okay, so maybe you won't start a fire. But you might make bananas and generally f**k your engine. Which isn't cool. Swallow that spring, or make some kind of micro-sculpture with it to sit on your mantlepiece, leave the Motronic ECU in your car and go have MRC map it professionally. Also, don't take street heroin, don't talk to strangers and always be sure to tie your shoelaces.Last edited by Dan; 1 April 2011, 18:04.1993 ABY Coupe | BMW R1200 GS
A6 3.0 TDI Quattro (aka Sonic's 'ring support/cargo vehicle
)Comment
