the other day i was drivin my s2 and all of a sudden it started to missfire i thought it needs replacement coil plugs bought them its still miss fireing what should i do next guys im lost i think it might be a possible air leak might be suckin in air
Seems there are lots of things which cause problems, so annoying.
I had my second air meter (MAF) replaced a week ago (under warranty) and my car was running really well, but it wasn't by last night - though I suspect a heat related problem as it had been running hard and fast earlier before I parked it, and five minutes later I was driving again and it just wasn't right. Heat soaking into the engine bay when the car isn't moving, and it was a warm day - anyone got any thoughts on this?
Air leak sounds quite likely but I will leave it to the experts to decide! Maybe my problem is even an air leak brought about by the temperature rise?
__MDC__
Martin Cutting
i think what might have caused mine is that i put CATACLEAN into the ptrol tank of my car and that f**s about with the emissions it might be that ****in its a pain in the **** it only happens once the car is warmed up i think that it could gbe something sucking in air !!
i took out the spark plugs to find they been covered with black stuff i think thats down to too a strong mixture what puzzles me is that i put my foot down and thats when it started to miss fire no its like that all the time
i m gonna go get the car tuned up see if it has got something to do with emissions. But what is a MAF ?? im gnna put new plugs in there and see what happens then go for a tune up
There arent any settings for a 'tune up'. The car is completely ECU controlled. MAF= Mass Air Flow sensor, its located on the airbox with a big electrical connector on it. Try cleaning the connections with some spray contact cleaner. If that doesnt help then check boost hoses for splits or holes.
Tom C - www.rcmr.co.uk
Audi UR Quattro
Audi 100 C3 2.0 5 cyl 115ps
Audi B5 RS4 645ps 911nm
try to change the lamda,it might gone,then you get very rich with petrol...then you check the ignition switch,low volt to the coilsystem,gives bad sparks
