right people as my G40 sensor has failed recently putting the kibosh on my trip to the ring, i have decided to change the cambelt on my URS4 as the pulley has to come off anyway and the belt is due to be changed aswell, but first a couple of questions
1) what bits do i need to do this job? obviously the belt itself but what other things should i change while im at it e.g. water pump, other belts etc.
2) is there a locking tool that i can buy that will fit both my aan engine and as it will also need to be done during the resto my aby engine in the s2
3) what ar the torque values for all of the associated nuts and bolts like the cam pulley bolt etc.
cheers for all the help peeps
dean
dean
at the torque of the crank bolt i think i will have to borrow one of works torque wrenches for that as i dont have one that will get anywhere near that
