11mm ARPs? 88 is WAY too much IMO. IIRC the OE bolts are 85, and as they are bolts they have a higher friction on the threads etc.
Thanks to Pirvu Eugen for the original documentation - it's nice to have the manufactur's black-on-white and it does indeed say 80 lb/ft with their lubricant.
I'm surprised. The Audi 40Nm, 60Nm and 180 degrees CERTAINLY produces more than 85 lb/ft. I've never actually measured the torque, but I know that if I do up a head with my normal extra-long FACON 1/2" tool I'm pretty knackered by the end of it.
My tool of preference is a 3/4" drive extra-long breaker bar, and even with that you feel the last few tens of degrees.
A friend has an electronic Snap-Off torque wrench that can be used in recording mode - opportunity permitting I'll use it on the next head I do and see what the Audi torque-to-yield procedure produces. But I'll bet it's a DAMN sight more than 85 lb/ft.
This is half the problem though... My kit does not say 80Ft/Lb! I will dig it out when I get home...
Nothing wrong with Audi bolts, apart from they are one use items...
ARP studs are re useable.
Ah, OK.
But Audi's bolts require no post-tightening - from what I read here (no personal experience) ARP requires checking after a hot-cold cycle, 250 miles and 1,000 miles. For most (all?) of my customers that's impractical.
Plus on 20V engines there's a fair amount of wear and tear on the cam cover gaskets getting back in and out.
Yes I can see that being an issue. I guess ARP is a benefit for 'self fitment' where you may have a need to remove the head a few times. For a standard head gasket replacement due to blown gasket etc, audi bolts are probably a better bet.
I dont know.....but...maibe, iff we tight the arp's at this 80 ft/lbs will not require retorque.
I have tight the bolts received with this torque...80ft/lbs disregarding the figures given by you guys here on the forum . I have installed an old cam cover gasket just to heat up the engine first time and then i will remove and recheck the torque.
I will let you know the result. Iff i will be able to retorque the bolts with the torque wrench fixed at 65 ft/lbs.
All the best!
What do you think about elring? I hear that it was a good brand
