Name that part
  • driftin jo
    • Sep 2007
    • 2222
    Originally posted by HORCH
    dam it, surely I wont have to take the head off though?
    No...you won't have to take the head off but you will have to take the engine out.
    • driftin jo
      • Sep 2007
      • 2222
      Seriously though you will be able to put a new plug in if you use a little ingenuity .
      • HORCH
        • 330
        hahaha thank god for that, I was worried for a second there, I'll find a way,
        • HORCH
          • 330
          can someone tell me where these go please? I'm putting my exhaust manifold on I've got the one thats definately the exhaust gasket but these have confused me?
          • Tonks4x4
            • Nov 2005
            • 3062
            Spare set for different type of manifold I believe they are for the 7A 20v engine
            Audi Nut!!!
            • mcandmar
              • Apr 2004
              • 5118
              Yup, early 5-1 tubular manifold uses those separate gaskets.
              91CQ20v - Gone to a new home
              93UR-S4 - The Magic Carpet
              94S2Bus - The Emerald Express
              • HORCH
                • 330
                I did wonder, but I thought I'd ask, you seem to learn alot by putting a cyinder head on
                • HORCH
                  • 330
                  I'm looking at my radiator fan now because it comes on soon as you connect the battery up, I've read its a faulty earth somewhere, whats this though? it comes from the loom that joins to the fan, does anybody know where the earth for the fan goes to? cheers
                    fan resistor I think, its a 3B specific part AFAIK
                    • willg54
                      • Jun 2009
                      • 2055
                      are the earths down on the front left, underneath the washer bottle region?
                        Thats the fan resistor, it mounts to a hole on the fan support. (I can take a pic of mine if you want) Fan just has the 3 pin plug, not sure where the earth goes to the chassis..
                        • willg54
                          • Jun 2009
                          • 2055
                          on this plate here i think
                            nope thats the ABY fan resistor pack, different to 3B
                            It doesn't really matter where the earth goes, there is a point nearby on the ABS pump bracket, or you can drill a hole and make your own one whereever
                            • HORCH
                              • 330
                              ahh right, yeah I took it off the fan shield, well the car is a 3B so if thats off an aby would it make it stay on? does the fan work by earthing or the earth being broken? by the thermo switch?
                                Originally posted by mcandmar
                                Ok, if you have torqued that nice clean head gasket down your not going to like this. The large hole should have a core plug in it sealing off the coolant jacket. The small threaded hole is the engine temp sensor, has a white 2 pin plug on it.
                                Here is a photo with the G62 engine coolant temp sensor that the ECU uses.
                                Unlabeled photo courtesy of Tom S. (RS2 America)
