can eney one help me with this problem my s2 3b has started to run lumpy i sprayed wd40 on cables at the back of the engine restarted the car and it runing like a dream a couple of days later then starts to go back lumpy eney ideas to what this can
whats it up to?
Tags: None
What cables ? Sounds like it could be coil / HT wires or maybe a sensor wire you sprayed it on. If the insulation on these wires is shot then WD40 would drive out the water and temporally stop them shorting out and thus stopping the miss fire. -
i spray it near the dizzy the ht cables are newish but i insulated them on friday i put a new coil on thinking it was that but its stil the same just thinkin may be could it be the hall sensorComment
no i cleaned the icv on friday and it was pretty clean and it worked i checked it before i put it back on it opened and closed didnt look liked it was stickinComment
Wait until it is dark out. Start your car and open the hood. Observe any blue sparks coming from the high tension leads coming out of the distributor.
Replace leads.RS2'd 93 UrS4 5 spd sedan
When you say you have put insulation on them do you mean insulation tape ?
If you mean standard electrical insulation tape this will not help if you HT leads are shot.
It is not designed and cannot cope with HT.Comment
You shouldn't wrap anything round HT leads, it only makes things worse.
How new are your spark plugs?Comment
