once and for all..crank breather for track AAN
  • AndyP
    • 6049
    Check out the schematics on this thread
    • x6rs
      • Dec 2010
      • 134
      it looks like im on the right track here
      • x6rs
        • Dec 2010
        • 134
        what do you think of using an industrial oil/air separator like the ones you use on an air compressor? glass bottle, fittings on top with filter inside, drain in bottom.
        or is there a better design? spent some hours yesterday searching for the ultimate oil separator design and i guess theres a reason why painters etc use the "bottle" type.
        drawings and ideas would be nice if someone got
        • A80Avant
          • 10873
          • Country: Greece
          i bought a provent tank to use but didnt have any room to fit it. if you like i can sell it to you
          • x6rs
            • Dec 2010
            • 134
            got pics of it? i dont have plenty of room either, i have an urquattro with aan.
            my plan was to fabricate it myself, just made myself some diff/gearboxmounts, why buy when you can struggle for hours making it yourself
            but whats the price? euros or dollars is easiest to understand
            • A80Avant
              • 10873
              • Country: Greece
              #21
              here it is
              http://www.efiexpress.com/catalog/pr...products_id=52
              thats where i bought it from
              the only thing i have done to it is remove one check valve membrane that it has on the outlet, as it wouldnt work with our engines. Unfortunately i dont know where i have placed it. The bottle itself should work fine, but only in combination with a second tank i believe. Some say that it works fine on its own, but i never used it due to lack of space.
              • x6rs
                • Dec 2010
                • 134
                how big is that thing? and is it the filter maker MANN that does them really?
                why doesnt the membrane work with our engines?
                • A80Avant
                  • 10873
                  • Country: Greece
                  #23
                  cause it closes when on vaccum and that exit goes to the turbo which is always under vaccum
                  • x6rs
                    • Dec 2010
                    • 134
                    am i getting this right? the membrane valve is connected to the inlet of the turbo and blocks off when on vacuum? why would they do such a valve when you want vaccum in the crank? why would they use a valve that blocks vaccum?
                    • A80Avant
                      • 10873
                      • Country: Greece
                      #25
                      because it may have been meant to work on non turbocharged engines.OR in a different manner. BUt that exit on the bottle, once you applied any vaccum to it above a certain point, it blocked, so i removed it.
                      • x6rs
                        • Dec 2010
                        • 134
                        did it work? havent read so much about the provent, but will it work?
                        maybe you can link to some threads about it?
                        • A80Avant
                          • 10873
                          • Country: Greece
                          #27
                          noone has ever used it yet on our engines. I was told by Marc(efiexpress) that it should work adequately on it's own,but when you are burnt in a problem you tend to overcorrect, so i was going for 2 tanks. Eventually lack of space meant that its now on sale. Maybe i could use it once i take off the hydraulic brake servo and create more room, but i doubt it, as my system now works.
                          • x6rs
                            • Dec 2010
                            • 134
                            take a look at this one:
                            the provent 200 has a limit of 335 hp....
                            provent 400 makes it up to 670hp.. so i guess you need a 400, but 160mm in diameter and 301mm tall, quite big
                            • A80Avant
                              • 10873
                              • Country: Greece
                              #29
                              Oh yes, i knew that and initially wanted to use 2x200 provents in line, as the 400 ... you need to put it in the trunk! its way too big! haha
                              eventualy that 200 didnt fit, by a small margin though, but didnt.
                              • x6rs
                                • Dec 2010
                                • 134
                                ok.. now im thinking of installing a vacuumpump also, but cant find a suitable one, volvo 850 has an airpump that should handle the flow, but does it work with oil fumes and create vacuum?
                                and how do you install an electrical one, you want the vacuum to follow the revs, so that you dont get to much vacuum on idle and not too little on WOT..
                                any ideas on a suitable one?
