Fixed it!!
  • DJones
    • Jun 2005
    • 2020
    Fixed it!!
    I have had this whistling leek on the exhaust side for some time now, was damned if i could find it....
    Anyway i made a smoke pressure tester, and hey presto found it straight away. It was the bottom bolt that holds the turbine housing to the bearing body on the turbo.
    Had to be the most difficult one to get at, hidden behind the oil return flange...
    Any way all sorted and as quiet as a mouse, there was me thinking it was a cracked manifold...:corey:
    Darren.
  • AndyP
    • 6049
    Just found a similar leak on mine, found with good old soapy water sprayed on the turbo while pressurising it.
    How did you make the smoke tester? Mark used one when he did mine and it was very useful so I looked it up when I got home, it was £800
      Nice one. How did you do the smoke?
      • DJones
        • Jun 2005
        • 2020
        I welded up an 8" cube and welded a screw on lid on one side. I then welded two male push fit connectors to place it in line on the compressor hose.
        Lit a smoke pellet (what you use for testing flues for leaks) and dropped it in the cube screwed the lid on and turned up the pressure, hey presto...!
        The pellet only burns for 40 seconds but it leaves plenty of smoke behind..
          Flash
          • djh
            • Jun 2011
            • 1622
            any pics?
            • s2driveruk
              • 12696
              very clever and glad you found it not exactly low on performance though was it
              1992 3b S2 Coupe
              • DJones
                • Jun 2005
                • 2020
                Lol, no but they are like your kids, you know when something's not right...
                • DJones
                  • Jun 2005
                  • 2020
                  Originally posted by djh
                  any pics?
                  Sorry no..... my kids borrowed my camera and have some how made it vanish.. Not sure pictures would give you anymore in truth. Its just a square box with a lid and two pipes sticking out either end...
                  • Bram
                    • Aug 2006
                    • 2582
                    nice find Darren!
