I thought it would create a follow on thread to my engine failure earlier this year,just to show other members what to exspect.I have to say it has been difficult at times,mostley dissiding which is the right way to go.
You set out on what you think is the best coarse of action,then some one suggests a better way which throws you into doubt.
This is the story so far.I bought a doner car with what I thought was a good engine but with a smokey turbo,thinking I could get away with a quick swap,this was not to be, on closer inspection it was not just the turbo. This ment another engine or a complete rebuild,me being a gluten for punishment dessided on the later.
The engine after I sold the doner car was basicly free so it seemed the right thing to do.
I was still addement that I should keep the hamer down and complete the project,so I stripped out the engine and found it needed a rebore, which means new pistons,the crank need grinding,both mains and big ends.The head from the doner car had been polished and ported and came with a 7A cam which was a bonus, but it had suffered a litle corossion around the water ways,not to bad but it was not as good as the head on my car so I used my original head.
When the head was stripped out,it was 117.9 through the bolt holes,Audi say the minnimum IS 118.1. problem number one had arrived what to do next.
The head had obviously been skimmed before,but it was in much better condition than the other head,so I am using it with a thicker gasket made from two gaskets.
The next problem was with the block,first the deck needed a skim and the front locating dowl
would not budge, front one went right through the casting so could be punched out from under neath, the front one i s stop drilled and would not move,and as are harden you can drill them out.
As you can see there are problems after problem,and it is not the end of them.
However I will try and add some pictures to help explane the 0ther issues,of which there are many.
On a brighter note I have picked up the engine bits today and they are now all cleaned and prepped for the rebuild,along with the new pistons,conrods and gaskets,so wish me luck and I will post some pics as soon as I can
Don't often see the spelling police on here!
