Hi,
Well i can get 1.4 bar of boost on my car, i think this is normal for my hohenester tuned S2. However, it starts to drop a little bit later and stay on 1.0-1.1 bar. Could this be a boost leak or simple something that hohenester programmed?
Well wrote this to hohenester:
Hi Honester
I have an 1992 Audi S2 (black) which has been tuned by your garage at 12.08.2000 Nr. 001230 KD-Nr: 2249. The car has 310bhp and boosts at 1,3 bar.
I have a question, is correct that when the car reaches 5000 RPM with full boost, the boost start to fall and redlines with 1.0 bar instead of redlining with full boost 1.3 bar?
If this is not correct, can you tell what the problem could be? The car is runing fine anyways.
Best Regards
Jonas Rohde
Got this anser:
Hello Mr. Rohde,
the questions are:
1. What is in the Computer wrong (Diagnose)?
2. Is the Pressursystem o.k?
3. Is the westgate ok and the Pip on the way?
I have no dianoses, however i guess the pressure system could be off.
/JOnas R.
Hi Honester
Best Regards
Jonas Rohde
Got this anser:
Hello Mr. Rohde,
the questions are:
/JOnas R.
