S2 ABY Wont start
  • Biggss2
    replied
    Hmm il give the relay a go Aswell... with the plugs I disconnected them to check for a spark they kind of smelt like petrol but the last couple were oily :$ I've stumbled across Pauls loom/wiring diagram this will be really useful should I decide to scrap the immobilizer!
    replied
    Add to list, activate fuel pump to see if it runs. Bridge contacts or pull the top off the appropriate relay and close the contacts by hand.
    If car ran fine and one day would not start it could be the fuel pump died, my avant went like this. Started the car, it ran for 10 secs and died, would not restart.
    Its strange that 2 plugs were wet and 2 were dry (and what about the 5th? )
    I have removed a few immobs and alarms, it a matter of following the wires from the immob box back to where they've been spliced into the loom and repairing the loom back to stock. Usually at the ignition switch and at the ECU. If you have total closure then you will have wires in the door jams too which is a bit more messy ..
  • Biggss2
    replied
    To do
    Check timing on bell housing/flywheel looking for a 0 mark
    Check the plug on dreaded immo box for heat damage/black marks
    On the backburner: CPS (was so close to splashing out £130.00 from tps today until I read pauls thread on non starters) & lambda sensor
    Guys where I'd be without you.. Heavily out of pocket and Quite simply without an s2!
    Can't thank you enough
  • Biggss2
    replied
    It has a multipin connector and with that it has 4 yellow wires that have 2x 5amp fuses on them.. How hard would it be to disconnect the immobilizer and throw it away?! The thing that gets me is that upon cranking the engine sounds so healthy and as if it wants to go!
    replied
    If the immo box has a multipin connector on it, pull it out and check there are no black pins or signs of heat.
  • Jonnybravo
    replied
    Originally posted by Biggss2
    Aaah cheers James.. Thanks ever so much for your help that day was really kind of you considering I wasn't even a forum member yet! I'm hoping there Is light at the end of the tunnel!
    No problem at all, Paul will see you right when it comes to the electrics ! very complicated stuff but he certainly knows his way through it.
    replied
    Ignore lambda probe for now... unless you have a multimeter you can use to test the blighter ?
    Laserline immo - yeah - its a worry alright... these things are easy when i am hands on - but describing every step of electrical tests to anyone who is not comfortable around electrics is horribly complicated and subject to confusion.
    You suggest you are seeing 'weak sparks' now - that kind of rules out ECU control logic and G40 as thats either a go or no-go decision based on presence of RPM and CMP signals. If spark is weak then it suggests a problem with 12V supply to the POS units or a bad earth from the coils - check the fat brown cable coming from coilpack cover is nice and tightly grounded to top of engine.
    The immo could be interfering with 12V power to coils or the ECU... can you privately send me the colours of wires that the immo is wired to - on the fcatory loom I mean ?????
  • Biggss2
    replied
    Paul.. The thing that worries me is there is a big ugly laserline box on the car with some wires fuses going to it I'm not really comfortable with messing as I don't want to make the issue worse.. The car itself ran fine until it give up ghost one day. I'm going to check the timing via bell housing tomorrow.. Hall sensor seems fine as I've got it where I can disconnect it no spark connect it and get a weak spark. Would it help me replacing the lambda sensor or is this a lost cause right now?
    As for changing the loom I'm guessing that a) it's going to be a complete pig of a job and b) the loom itself is going to be as rare as hens teeth
  • Biggss2
    replied
    replied
    Couple of pointers....
    1 - fuel pump does NOT prime on S2 so thats not a worry
    2 - search the forum on building a fuel pump 'hacktivator' so you can test fuel delivery without running the engine
    3 - the fact that S25 blows on cranking says a couple of things... firstly that pump relay is getting activated by ECU - which means it is broadly happy with RPM signal from G28 sensor... and secondly that some odd **** is happening cos either a loom fault is creating a short circuit on the S25 path - or the lambda probe heater itself is shorted.
    4 - with ignition on, check you get 12V at one side of the fuel injectors and that the white 3-pin plugs on the POS connectors are also 12V.
    Oscilloscope is the only way to ascertain if G4, G28 & G40 are healthy and aligned... I have posted plots of that in the past which will help any auto spark worth his salt even if he doesnt know any specifics on S2 wiring and such.
    Are you certain its not some immo/security issue ?
  • Jonnybravo
    replied
    I'm sure you will find the answer on here shah, it's a extremely useful forum.
    James
  • Biggss2
    replied
    Sorry just read, I'm in the west midlands near wednesbury.. If there is anyone local who can have a gander/get it going I have some red notes at their disposal..
    Many thanks
  • Biggss2
    replied
    Great I'm going to give the bottom crank pulley a look tomorrow.. Gone dark now and I'm soaked through again I really appreciate your help guys..
    I really dont want to give up in her.. One other thing The fact that I've disconnected the lambda should still allow the car to start right?
    Cheers again
  • Ross
    replied
    Easy once you've done it the first time. I'm not actually sure on an S2 bumper anymore but on RS2 it's easiest to take the fogs and indicators out and theres two bolts easy to access, then take the screws out from the cowlings under the wheel arch and pull it forward. I think on the S2 it's just a case of taking the grills out (?) Or you may get to them going in from the top, albeit a little more awkward..
    Oh yeah if you still have it - undertray off too
    replied
    Check the crank position at the flywheel, the mark on the bottom pulley is not reliable. There's a window in the bell housing, you're looking for a 0 (zero) mark.
    Bumper, if you did need to remove it, comes off with 2 (or 3?) screws each side in the wheel arch (could be seized, soak with plus-gas or wd40..) and a bolt each side (going outwards) behind the fog lights. Need to take headlights, indies, and fogs out.
