Whoa a big thing pops out, you've got the 3rd trigger on the camshaft enabled!!
urs4 big turbo starting issues....
i agree but don't know spec of turbo and inectors etc plus Marc can supply better values.
try that, all i've done is removed all the errors except one which doesn't matterAttached FilesComment
ok great i will give it a shot tom, thank you, and how to i upload this map back into vems? (sorry newbie with vems)
and that third trigger being enabled could that be the problem for causing a non startComment
http://www.vems.co.uk/forum/ Lots of stuff hereLeif-Helge
-91 S2 VEMS and Comp Turbo
-12 B** 530XD Touring "S2 parts transporter, and daily driver"Comment
Audi finally got started, wasn't a tune issue like one of the guys here mentioned to check the lines going to the regular, which i completely forgot to check that day and it ending up being the problems i had the lines going the wrong way, thanks to Marc solving the problem car now runs will go and pick it up Tom, just wanted to thank you guys for all the help trying to diagnosing the car ( coulnt do it without you all) always knew it was something stupid :/Comment
