Ok - s2 ABY avant was running, didn't stop or misbehave just refuses to start next day.
I've taken the lid of the fuelpump relay and that works, when cranking it pulls shut.
You can hear fuel circulating when you artificially bridge the relay.
Checked injector terminals with ignition on - no volts
Checked coil power plugs with ignition on - no volts
Checked all fuses in the main fusebox - all ok
I've pulled the ecu out of the footwell and visually there seems to be no broken wires or dampness
So.....
Where do I go from here?
So.....
