Hey guys... My S6 presented some ignition issues after 3 months of hibernation... like and occasional misfiring trouble. I did some tests, first of all, replaced the coils cooked ground wire for a freshy new one, cleaned the F5DP0R spark plugs with about 80K kms on it...and ... nothing solved... My fear was for a coil(s) failure (it's such a pain in the a**)...so then realized about the POS units and got a pair of them that were from my ex-CoupeQ with an AAN on it. Okay well the problem was the POS unit of the #1,2,3 cylinders....I replaced it this morning and now it's running fine again.
Now I want to replace the spark plugs, my car runs 100%stock for now, and my plans are to go not over the 380hp barrier for next year. The F5P0R spark plug in the only shop inside this town, it's price is 38euros EACH, it's quiet expensive and I need the car for tomorrow. My question is...is there someone running the tri-electrode bosch FR5DTC on their AAN/RR/3B/ADU/ABY engines? I red on 034Motorsport there are some 5 and 6 heat range sparkplugs and even a resistored and non resistored ones that one of them may cause issues on the dashboard function under boost. Thanks in advance guys...
P.S.: this was the problem I had on my car: http://www.youtube.com/watch?v=8IWgU...el_video_title
