Black Smoke and Lumpy then Gone !
Code 0537 Details
2341 (Blink Fault Code), 00537 VAG1551/2 Fault Code Number
Oxygen Sensor Control Limit exceeded:
fuel pressure too low or too high, intake or exhaust leak, defective ignition system component, intake air leak after air mass sensor, O2 sensor is faulty
So based on your new story (which you should have told us earlier) about your initial turbo install leaking oil into the exhaust downpipe, you might have an O2 (Lambda) sensor with a coating of burnt oil on it. At the very least, you are going to have to remove the O2 sensor and check and possibly clean it (carb cleaner??) and reinstall. Otherwise, you will have to replace it. Audi PN is 034906265F. Here is some O2 sensor info:
Well at least you found the problem. The Audi PN is 034906265F, as I posted above
. Same as AAN, ABY and ADU and 7A, NM, MC, etc. etc. extremely common Audi part.
When you put it back together make sure the sensor is not rubbing on the heat sheild on the bottom of the air box.Comment
