Ground-hog day here...
I'm now half way through installing the same engine into my 4x4 VW T3 Camper and I'm at the same stage as before... but I can't remember what I did to get it to run again other than it was as simple as 2 x wires!!
Unfortunately the S6 Auto that I borrowed is now abroad in Europe.
MG
MG
, I am also pretty sure that you cannot generate more than 6 psi while blowing down that hose. I suggest that you disconnect the hose at both ends, clamping the rubber end at the ECU and using a small compressor with a pressure gauge, run the pressure up to 10 psi (maybe 15 psi). My guess is you will find a split somewhere.
