boost problem/cut out
  • AQTdriver
    • Jan 2011
    • 750
    This just made me think- my MAF is inside the wing with the air filter and a vw transporter vent has been put in place so could it be that ecu just doesn't like any disturbance in MAF - ecu circuit - because obviously some moisture and stuff gets in there...
    '93 S2 Avant breaking
    '95 S6 Avant sold
    '83 80 Quattro SWB
    '85 90 Quattro
    '85 200 Quattro 10V sold
    • Biturbo
      • Aug 2011
      • 591
      • Home: Lithuania Current: United Kingdom
      You can check faults in most car garages,this is first you need to do.When you get faults then we can help you .In my car was just fault clear it and no problem
      • prj
        • Mar 2010
        • 6308
        The same can be done by switching ignition off and back on again.
        Until the condition occurs again, which put it into limp mode in the first place, it won't happen again, and the fault will be stored as "intermittent".
        If it does not go away when cycling ignition, it won't go away by clearing codes.
        Plus, to clear codes it is sufficient to disconnect the battery for a second or unplug the ecu from it's connector and then plug it back again.
          Or remove the 2 "Motor" fuses in the fuse box.
          • Biturbo
            • Aug 2011
            • 591
            #20
            But if is not read fault then he don't now why is put into limp mode.Always good check it some times if you care about car
            • prj
              • Mar 2010
              • 6308
              Yes, it is good to always read the faults, but as I said, instead of clearing them you can just turn ignition off and on. They will be stored as intermittent if the cause is not present anymore.
              • AQTdriver
                • Jan 2011
                • 750
                Thanks guys! Let me try...
                '95 S6 Avant sold
                '83 80 Quattro SWB
                '85 90 Quattro
                • AQTdriver
                  • Jan 2011
                  • 750
                  Car is absolutely fine this morning!
                  I guess reading faults will be a good idea...
                  '95 S6 Avant sold
                  '83 80 Quattro SWB
                  '85 90 Quattro
