chiped 3d
  • sla_s2
    • 166
    chiped 3d
    any comments about this curve? does it look normal to you guys?
    sla s2
    sla
    '91 s2 3b, 305hp, 480 nm.
    www.4plius.com
  • sla_s2
    • 166
    i have to add turbo is stock.
    s
    sla
    www.4plius.com
    • porkkis
      • 1994
      Seems normal and OK. My top torque was a bit lower. Quite precisely on the 3000rpm mark.
      BUT I have a ported head. Dunno if that would make such a difference.
      • sla_s2
        • 166
        seems like i need a bigger turbo or boost controller first
        s
        sla
        www.4plius.com
        • Mihnea
          • 1288
          Sla, what chip is this? There is too much boost/torque at low revs, which prevents the engine from making full power after 4700 RPM. This comes from pinging because of too much boost at low RPM, although 470Nm sounds nice. But, 470Nm is TOO MUCH TORQUE for a standard engine!!!!
          HTH,
          Mihnea
          www.MRCTuning.com
          info@MRCTuning.com
          Workshop Directions
            How much boost? Mine was peaking 27lbs on the stock turbo at one point and it was really good fun, It really boosts up fast doesn't it, and kicks the car down the road, I was told the turbo would blow though, you could hear it overspinning...
              Oh yeah it would slip a brand new clutch too
              • sla_s2
                • 166
                mihnea, it is digitech chip, peak boost is 1.5 bar and it drops to 1 bar.
                sla
                sla
                www.4plius.com
                • sla_s2
                  • 166
                  that is why i got ceramic clutchnet clutc up to 400hp
                  sla
                  sla
                  www.4plius.com
                  • SteveH
                    • 4460
                    Sla, could you provide more information on the clutch you have? Mine is slipping from 4K in 4th and 5th gear. I need something stronger to cope with the torque. However, my car is used every day in town traffic, so I need something that will last and isn't on and off.
                    Cheers,
                    Steve
                    91 Modded 3B
                    14 A6 Avant Black Edition
                    • porkkis
                      • 1994
                      Steve, try Sachs Race Engineering pressure plate with standard disc. The pedal will be heavier to use, but should cope with over 500Nm.
                      • sla_s2
                        • 166
                        steveh, yesterday was the first day i drove the car with this clutch, but it feels good. i got (http://www.clutchnet.com/make/prodDesc.html#6bEZ) Racing 6 Button "E-Z LOCK PRO" â„¢ Sprung Hub installed. the pedal feels quiet light and it grips
                        sla
                        sla
                        www.4plius.com
                        • Mihnea
                          • 1288
                          Sla, the digitech chip is an ebay chip, thanks but no thanks, I've seen it loads of time already. You have no knock sensors in there, so watch out for pinging on bad gas quality.
                          Mihnea
                          www.MRCTuning.com
                          info@MRCTuning.com
                          Workshop Directions
                          • sla_s2
                            • 166
                            no, it is not an ebay chip. just checked the fuel mixture with wide band, it could be leaner...
                            sla
                            sla
                            www.4plius.com
                            • Mihnea
                              • 1288
                              Sla, the only reason why your mixture isn't leaner is because the ECU is detecting pinging from too high timing advance, retarding all the way and dumping more fuel inside the combustion chambers to keep the engine from knocking.
                              DigiTec chips don't come from Ebay, but chips sold on Ebay are the digitec ones. Digitec stole this software from MTM who initially developped it in 1991 for the DTC series S2s that were running big turbos, lower CR, different intake manifolds and intercoolers and bigger injectors. The base fuel mixture is too lean at WOT and it's only because of pinging that it's rich enough...
                              HTH,
                              Mihnea
                              www.MRCTuning.com
                              info@MRCTuning.com
                              Workshop Directions
