I meant measure the values, which i think you knew full well!!!
Measure pressure under acceleration? As in boost pressure with a mechanical gauge, if so then i've done that and all is the same as my 'controll' car i then scrapped and now regret!!
Compressions when i checked after fitting the head were within 1-2 psi of eachother and all correct.
