URS6 Way Too weak!!!
  • prj
    • Mar 2010
    • 6308
    Originally posted by HMS-S6
    No. I've worked on various cars for 15 years, i was the only car there. It was pinking i'm sure, was just coming on boost next to an armco just as it hung back the pinking stopped.
    And I'm sure it wasn't. Let's leave it at that.
    • HMS-S6
      • Jan 2010
      • 1164
      #122
      Originally posted by prj
      Sorry, but that's not happening. Only thing you can hear is wind noise with the windows down. You might be hearing some noise, but it sure as hell is not det.
      I have mapped tons of these, and I always have a mic with an amp connected directly to the engine block. Not a single one of my customers has ever heard anything ever, and it is not that loud using an amp and a direct mic.
      1. Timing you see in VAG-COM is not backed off. You only see requested timing sent to the knock/ldr processor, and that backs off timing, you get the value before that happens in VAG-COM. Displayed requested timing does not change even during heavy knock.
      2. You are assuming the car is running lean, you have not done anything to verify this as a fact.
      3. You said the car boosts 0.8 bar on standard ECU. It should be boosting 1 bar. Use only the standard ECU, don't use a chipped one, as there is no telling what is inside it.
      Can you recomend anyone who can look at the car and cure it?
      • prj
        • Mar 2010
        • 6308
        Maybe will20v wants to have a go.
        • HMS-S6
          • Jan 2010
          • 1164
          #124
          Where is he based? I've been to a so called specialist before who couldn't really be bothered which is why i'd realy like someone recomended who really knows I5's
            I pressure tested the car with all the hoses on. I.E Intake manifold in with the test. Also, i have to say that i have a mechanical gauge in the car from another take off and they read like for like.
            I think I knew that you pressure tested the entire intake. This is a bit different. Typically a pressure test of the intake doesn't go much above 1 Bar. What I am talking about is a potential split in the green plastic hose that opens up ABOVE the normal intake manifold pressure test pressures, preventing the ECU MAP sensor from getting the proper reading.
            You say you have a mechanical gauge. Where did you install the "T" in the green plastic line? What boost pressures are you seeing when you think you hear the pinking?
            • HMS-S6
              • Jan 2010
              • 1164
              #126
              Was reading 2.0 bar on the on-dash display. I have decided today that enough is enough with regards to my time though. I have as good as two jobs, a missus and a child, so between them i have not nearly enough time to spend on this any more (had none of the above when bought it, lol
                2.0 Bar absolute pressure on the dash display = 0.98 Bar (14.3 psi) boost = you have a boost leak, perhaps as I was suggesting.
                Don't give up quite yet.
                • HMS-S6
                  • Jan 2010
                  • 1164
                  #128
                  Thing is, for Audi specific tools (pressure test kit) I have to borrow everytime. I just haven't got the time or access to parts as a I5 specialist will.
                  • K7ERG
                    • 1711
                    Run a new boost line from ecu to engine bay. Worth a try. That will save pressure kits etc. Fairly quick to do even a temp install to eliminate.
                    Don't give up and I also know what its like with the kids, work etc. Keep with it.
                    Craig
                    Audi A6 AEL 5cyl Quattro breaking.
                    Audi A5 3.0tdi Quattro Stage 2
                    07947385043
                    • HMS-S6
                      • Jan 2010
                      • 1164
                      #130
                      Craig
                      Yeh i might just do that Craig thanks! It'd just be nice to have a knowlagable forum member closer to bounce ideas off
