Tfsi 2.0 coil pack Loom
  • bigcooler
    • Jan 2009
    • 229
    Hi guys i have tried looking for a wiring diagram for the 2.0 tfsi coil packs to ABY but cant seem to find much, has any one got a diagram as i would like to have a go at making my own.
    also is there any thing that i need to know when doing this with the ABY?
    thanks ben
  • Acidburn
    • 13459
    I'm getting some made up soon from my loom
      1.8t or 2.0 tfsi conversion details with wire colours, etc.
      Originally posted by bigcooler
      Hi guys i have tried looking for a wiring diagram for the 2.0 tfsi coil packs to ABY but cant seem to find much, has any one got a diagram as i would like to have a go at making my own. Also is there any thing that i need to know when doing this with the ABY? thanks ben
      The info and diagrams below will help you.
      The diagram that I created (with some drafting help) after doing the first ever documented conversion to 1.8t coilpacks (same for 2.0tfsi) on my 93 UrS4 AAN in 2005 (note: wiring colours at the harness connectors might be slightly different for the ABY - see second diagram for ABY wire colours):
      Here are the AAN, ABY and ADU wire colours that you need to consider when developing a 2.0tfsi coilpack harness for your ABY:
      Link to the original DIY from Oct 2005:
      http://forums.audiworld.com/showthread.php?p=18808309
      Updated version (with the extra photos used here):
      Subsequently, a fellow in Latvia found that Volvo had the necessary 4 pin connectors that are needed to connect to the harness POS connectors. Here are the details:
      If you have any questions, I will be happy to answer them.
      • cooperquattro
        • Jan 2011
        • 815
        any idea on a rough price pete ?
        • bigcooler
          • Jan 2009
          • 229
          Thank you very much for the info
          should be fun
          thanks ben
          • Acidburn
            • 13459
            Hey mate, i'll try find out and let you know.
            • bikerjim
              • Feb 2008
              • 1028
              Has anyone any idea how this would be modified to suit a 4cyl 1.8t AEB engine. Mine has just 1 POS.
              Sent from my GT-S5830 using Tapatalk 2
              • ian4455
                • Nov 2010
                • 787
                Do i need the N122 and N127 units for the V8 coil packs, I've wired these in my 3b but have not included these????
                  You have the three pin, bolt on coils, with a separate 5 pin Power Output Stage. It would be very easy to make the conversion to 4 pin 1.8t/2.0 TFSU non-bolt in coil packs provided two things are available:
                  1. The AEB ignition wiring diagram that shows the pins and wire colours for the POS.
                  2. There is a compatible 5 pin MALE connector that would take the place of the POS and connect into the 1.8t engine harness from the ECU.
                  The first one would be easy. The second might take some digging. I think the harness connector (with the female pins) that connects to the five pin POS is a 443906235. However, I asked my friend Katie and she can't find a matching male pin equivalent. That is not a defeat, just a set back. There will be something that will work. It will just take a bit of looking.
                    Hope you've sorted your parts shipping efforts as per yesterdays postings.
                    The latest V8 (and 4 pin 1.8t and 2.0 TFSI coil packs), eliminate the need for the N122 and N127 POSs because they have built in, internal, POSs. That was one of the main reasons I developed the conversion back in 2005.
                    I am not sure how you can get a 3B to function with five coils of any kind without running either an AAN or ABY ECU.
                      He's done a 3B to AAN pin swap and added a VEMS ECU.
                      • ChrisAudi80
                        • Oct 2011
                        • 236
                        • Home: Norway Current: Thailand
                        034MS (yeah, I know) sells a kit. Issam at INA deverloped it IIRC. You can also buy the whole kit from INA. Wirelooms, brackets, coils. It eliminates the ICM on the AEB.
                        INA thread or Vortex: http://forums.vwvortex.com/showthrea...-INTRO-PRICING
                        and the kit on 034: http://www.034motorsport.com/ignitio...s-p-22290.html
                        HTH
                        '96 UrS6 auto PRJ chipped E85
                        '95 80Q AEB VEMS E85
                        • tscheel
                          • May 2009
                          • 222
                          • Country: Denmark
                          I chose the easy way : http://www.ebay.de/itm/330744407432
                          It's still in the mail, looking forward to get it sorted.
                          I might have f** up, though - bought used coils for 3.2 : 06E905115
                          Can I use them, or should I go for 06E905115E ?
                          Cheers, Torben
                          '94 B4 Avant S2
                          • Drummer87
                            • Oct 2009
                            • 1644
                            • Home: United Kingdom Current: Scotland
                            Torben the kit you bought from the bay, was it good quality also can this be fitted to
                            The aby s2 coupe
                            Chris
                            • tscheel
                              • May 2009
                              • 222
                              • Country: Denmark
                              The aby s2 coupe
                              Chris
                              I'm not using it yet, but it seems fine. Good quality plugs and nice isolation everywhere.
                              An ABY is an ABY to my knowledge, so it should work. The POS's are on the firewall, right? Only problem I can think of are if the POS's are mounted further from the coils on RHD cars.
                              I see the price is going up, sometimes you can find it a bit cheaper in an auction.
                              http://www.ebay.de/itm/Kabelbaum-Sta...item4d037d6c1e
                              Cheers, Torben
                              '94 B4 Avant S2
