yes i am concerned on the firing/injection order issue. didnt seem right at all from the get go..... ya no more sequential injection...i know there are a few guys on here running the Dta's but each has their own way of crank triggering. not sure how they have their systems set. if i added a cam sensor at a later date maybe it could enable sequential ....or i can do vems. i did make it so i can put a factory ecu back in plug n play. maybe this ecu would be better off on my v8.
but lets go back to the basics. set Dta to 1 cylinder. 1 coil. no spark..... i don't think my ignition drivers can drive these or the ls2 coilpacks. i 'think' i need a 5v pull up on the signal from the ecu to trigger on the leading edge of the wave. i was only referencing that image for pull up diagram.
