2.5 vs 1.8t coilpacks
  • dspl1236
    • Feb 2008
    • 242
    yes i am concerned on the firing/injection order issue. didnt seem right at all from the get go..... ya no more sequential injection...i know there are a few guys on here running the Dta's but each has their own way of crank triggering. not sure how they have their systems set. if i added a cam sensor at a later date maybe it could enable sequential ....or i can do vems. i did make it so i can put a factory ecu back in plug n play. maybe this ecu would be better off on my v8.
    but lets go back to the basics. set Dta to 1 cylinder. 1 coil. no spark..... i don't think my ignition drivers can drive these or the ls2 coilpacks. i 'think' i need a 5v pull up on the signal from the ecu to trigger on the leading edge of the wave. i was only referencing that image for pull up diagram.
    '91 Pearl 3.6 V8 CQ - building
    '13.5 Jetta GLI - toy
    '15 Subaru Imprezzzza - work daily
    hausofdub.com
      Let's *really* go back to basics, i.e. the firing order is really 1-2-4-5-3, as cast into the head, as shown in Rikki Kitto's photo:
      • Wheeljack
        • May 2005
        • 219
        And because you asked, the pull-up resistor is used in a circuit to decrease the susceptibility to noise which can cause accidental triggers. It is essentially a soft 'spring' holding the signal 'off' until the ECU grounds it and pulls the circuit 'low'. A high resistance should be used to minimize current flow when pulled 'low'. It should be used on your ECU trigger, pin 3. SEMS may have it built in or as an option on certain channels.
        • dspl1236
          • Feb 2008
          • 242
          Thanks UrS4..i was thinking about...even if it was batching 5 coils for a v10...it would still be 1 2 4 5 3.
          Thanks cab9
          Allan@Dtafast got back to me and said to use a 1K pullup from 12v. I'll try that after work. I sent him an email back asking about the firing order as well.
          hausofdub.com
            Originally posted by dspl1236
            Thanks UrS4..i was thinking about...even if it was batching 5 coils for a v10...it would still be 1 2 4 5 3. Allan@Dtafast got back to me.... and I sent him an email back asking about the firing order as well.
            Well if Allan comes back and says the 1-2-4-5-3 firing order is wrong, *HE* is wrong.
            • dspl1236
              • Feb 2008
              • 242
              Originally posted by gnutz2
              I run my DTA s100 wasted spark with magnetic (VR) sensor with 15-1 reference pins on the flywheel.
              Just set the engine up as a v10 in the settings and it will work.
              I understand all that can be gained by running a cam sensor is a small ammount of economy at lower (cruising) revs, not really what you want in a rally car.
              Originally posted by Audi_CQ
              Running 5 coils yes (with a HKS Twin Spark amplifier).
              Have run it as V10 in batch mode, but now sequantial with a cam sensor because I want to be able to adjust cylinders individualy.
              hausofdub.com
                And what is your point?
                • dspl1236
                  • Feb 2008
                  • 242
                  Urs4.. at this point i do not care what the firing order is..... it doesn't matter if I have ZERO spark. THIS THREAD WAS STARTED TO FIND HOW TO GET SPARK OUT OF A COILPACK. AEM and Megaquirt guys have the same issue with certain amplified coilpacks. all i am looking for is the coil to f'ng trigger. i have zero plans to find an aan ecu..repin my 3b ecu connector just to do your suggestion test prior to going standalone. i like your car and everything you bring to these forums....but dude
                  in 3 pages. Cab9fab is the only one who actually read and answered my question. again thank you.
                  back to firing order issue...thanks urs4 for seeing the bogus info
                  email to and from DTA
                  Originally posted by Me
                  Thanks Allan.
                  also if you have any insight to the firing order (1, 5, 2, 3, 4) in your instructions for the audi I5.... but the factory order is (1, 2, 4, 5, 3)
                  Just curious...i have had numerous people tell me i am going up my motor with the firing order provided.
                  Many Thanks,
                  Andy
                  Originally posted by DTA
                  Hi Andy
                  That is because they do not know what they are talking about. Connect the cylinders up in the order the pistons come to the top of the bore.
                  Forums are the last place to go for intelligent advice.
                  hausofdub.com
                    What I am saying is maybe the spark issue is related to the timing issue. You keep asking about the correct timing order when it is a given (1-2-4-5-3). If you set your coils up with your stand alone that way, maybe you might get some spark.
                    But hey, good luck. I still say buy an hour of Marc S's time and you will be miles ahead of where you are now. Good investment.
                    • dspl1236
                      • Feb 2008
                      • 242
                      all of my coils are wired in that exact setup you provided currently. there is a diagnostics mode in my ecu to fire the coils separately without the engine.
                      i even have a single coil out on the bench so i can put the DTA in single cylinder mode for testing. no go. I am picking up a $16 Ford 2 wire non amplified cop coilpack so i can give it power, ground to coil1 output, and ground the plug. i have not been home to try the 1k pullup on the current 4 wire units yet
                      hausofdub.com
                        Originally Posted by DTA (Allan)
                        Hi Andy, That is because they do not know what they are talking about. Connect the cylinders up in the order the pistons come to the top of the bore. Forums are the last place to go for intelligent advice.
                        Sorry, I am trying to leave these two DTA/coil threads but that quote from Allan at DTA is funny. For example, following his advice, how do you "time" a VAG inline four when pistons 1 and 4 both come to the top of the bore at the same time, like wise 2 and 3 rise as a pair? Coming to the top of the bore doesn't necessarily mean the cylinders are ready for spark, could be just the end of an exhaust stroke.
                        Maybe some forums are the last place to go for intelligent advice but this one is pretty good and I *know* we are dead on regarding the firing order.
                        There. *Maybe* now I can stay away.
                        • dspl1236
                          • Feb 2008
                          • 242
                          Now that this has been confirmed...stick with DTA instructions....can we lay off the firing order?
                          hausofdub.com
                          • Carfreak
                            • Apr 2012
                            • 225
                            Tryed the pullup yet ?
                            • dspl1236
                              • Feb 2008
                              • 242
                              not yet, just woke up. ill get to it shortly after i go raid a 02 wrx for new seats. yesterday i drove to chicago and back(800mi) so my buddy could pick up anther cq to s2/vems swap California car, very clean and no rust.
                              hausofdub.com
                                ... so my buddy could pick up anOther cq to s2/vems swap
                                At least your buddy is smart and will be using VEMS which has more technical and user support for the AAN/ABY etc that DTA.
                                (BTW I gave Marc S. at EFI Express the heads up that you might call him with your DTA issues - If you don't, that's fine too).
