Replace rods on my UrS4..
  • Carfreak
    • Apr 2012
    • 225
    On friday to Sunday I will replace my rods
    Just a question, which way should the rods be mounted, I mean which way the grooves for the bearings should go.. I´ve read somewere about this but can´t find the guide..
    I also wounder what size the crank pulley bolt has ?
    GRRR
    • Thuppu
      • 4115
      Here you go: http://www.s2forum.com/forum/showthread.php?t=42878
      There is also a really great pic in that thread.
      • Carfreak
        • Apr 2012
        • 225
        Awesome, thnx! Hahaha.. but the pic filled it´s purpose
        What size does the crank pulley bolt have ?
        • aronmatic2
          • 2129
          • Country: Hungary
          GRRR
          where did you buy the rods?
          Real carbon parts for S2 and RS2. Check Carbondesign on facebook
          • Carfreak
            • Apr 2012
            • 225
            Everything is bought from cp-service.se
            Got a nice price so
            • Carfreak
              • Apr 2012
              • 225
              I will start to rip down the engine tonight Hopefully everything goes as planed.. Can´t be that hard to change the rods
              Hmm.. do I need to do something with the oil sludge shield to make room for the ARP 2000 rod bolts ?
              • Carfreak
                • Apr 2012
                • 225
                Soon, very soon I will lift the whole package with im, em and turbo Just need to more hands to help me lift it off
                • Carfreak
                  • Apr 2012
                  • 225
                  Need some help.. can´t remove the oil pan :s It´s stuck between tranny and the pan :s any advice ? I´ve loosen all the hex bolt + the 16mm ones..
                  • AndyP
                    • 6049
                    Have you got the 2 bolts that are inside the gearbox bellhousing?
                    • Carfreak
                      • Apr 2012
                      • 225
                      I found them and now the pistons and rods are out I will soon reassembly everything with the new h-beam rods!
                      • Carfreak
                        • Apr 2012
                        • 225
                        Hmm.. what´s the numbers on STD rod bearings ?? My new bearings says STD but my old ones only has numbers on it..
                        • Carfreak
                          • Apr 2012
                          • 225
                          The project moves on this weekend!! New bearings has arrived and some plastiguage!
                          I must say that my engine is really nice inside.. the only piston that had small ping marks was the 5th one..
                          No feelable tdc marks in the cyls which is good, also a nice cross hatch pattern and now glazing at all
                          • Carfreak
                            • Apr 2012
                            • 225
                            The project is makin progress!! 4 rods and pistons are mounted. Both axial and radial play is measured. 0,050mm radial play and 0,25mm axial.. within specs I hope Downloaded the AAN spec sheet!
                            • Carfreak
                              • Apr 2012
                              • 225
                              I hope the radial play is right
                              • Carfreak
                                • Apr 2012
                                • 225
                                The job is done and the engine is started! Also found the problem to my rough idle The ISV and After run pump connectors was in wrong place I guess.. the ISV cables are brown and something and the after run is red and white ?
