Other modules are read?Is the fuse for diag ok?Do you have internet conection on the comp that you tried to comunicate with engine module?Do you use a 2+2 adaptor?If yes is it ok?Should ceck adaptor wiring,i had a bad one once.
What car/engine are you trying to read? Am I correct in thinking you have/had a 16v coupe? If it is this it may be the ecu is not compatible. I could never get my vag com cable to work with my 16v ecu. Try reading the ABS module or another car, if that works I would say its not liking your ECU.
Dont have the 16v anymore, this is on my 3B, ignition on, 2+2 adaptors triple checked. Will check that fuse after work its bound to be that knowing my luck.
