i have a problem with my rs2, after a head rebuild i bolted everything back together but now the car wont start anymore. i allready replaced the G40 camsensor and the G28 engine speed sensor but the car still wont start. i have spark so i assume the signal from the g4, flywheel sensor and camsensor is good. during cranking i cant hear the fuel pump running, is checked the pf relay and changed it for a known good one but still no start. when i crank the car i can see the fp relay bridge the contacts but i dont hear the fuel pump, also when i bridge the contacts on the fp relay by hand i hear some noises at the engine but i dont hear the fuel pump. the fp fuse is also good.
does anyone have any idea what could cause this ?
