AAN Vs ABY ECUs?
  • driftin jo
    • Sep 2007
    • 2222
    Originally posted by varia
    Bumping an old topic up, is the ABY and AAN (late) ecu the same?
    I believe ive read somewhere the map is different cos the weight of the cars.
    There is one difference apart from slight map changes and that is that the AAN ECU does not control the after run pump.
    Therefore if you fit an AAN ecu to an ABY S2 the after run pump
    will be none functional, unless you wire in your own circuit to control it.
    On the UrS4 etc with the AAN, the after run pump is controlled by a separate system dependant of the ECU.
    • prj
      • Mar 2010
      • 6308
      ECU is the same, calibration is somewhat different, because they were calibrated separately by different people.
      That afterrun pump stuff is software.
      • LHD_Kid
        • May 2006
        • 3696
        Hi Prj,
        So, does this mean that an AAN ECU can be made to control the after run pump with a remap?
        sent via Tapatalk
        • prj
          • Mar 2010
          • 6308
          Most likely, yes.
          I'd have to look up how it works exactly to give a definite answer.
          • driftin jo
            • Sep 2007
            • 2222
            I'm not certain what I said above is totally correct, as I was just told this many moons ago, the only thing I can say for certain is there is no input from the MFTS to the AAN ECU and I think this I why the after run pump does not work, although looking
            at the pin out of the ABY ECU I cant actually see how the ECU controls it anyway.
            • prj
              • Mar 2010
              • 6308
              The MFTS input kills boost, but apart from that I am not aware that it is used for anything else.
              I really have not looked into this much, but I can say that the hardware between AAN and ABY does not really differ, so any changes are software based.
              • driftin jo
                • Sep 2007
                • 2222
                I think it was Paul Nugent that told me, although I can't be certain
                of that either, there has been many beers and two babies since so things are a bit foggy in the old memory
                • driftin jo
                  • Sep 2007
                  • 2222
                  looking at the ABY pin out again I think this could be a red
                  herring.
                  According to the internet the after run pumps are all
                  controlled by module 324, looks like a relay but is solid state
                  electronics inside.
                  • prj
                    • Mar 2010
                    • 6308
                    Sorted then.
                      After-run Auxiliary Coolant Pump and Fan Switch and 324 Control Module Info
                      Originally posted by driftin jo
                      I'm not certain what I said above is totally correct, as I was just told this many moons ago, the only thing I can say for certain is there is no input from the MFTS to the AAN ECU and I think this I why the after run pump does not work, although looking at the pin out of the ABY ECU I cant actually see how the ECU controls it anyway.
                      That is because the MFTS and the ECU have ZERO NADA NIET NOTHING to do with the after-run pump system. All mechanical switch and 324 control model (yes it looks like a relay but yes it is all PCB and solid state devices).
                      I am pretty sure I have posted about this before here. Anyway, links:
                      Which came from this diagram by clicking on the Auxiliary After-run Coolant pump label on the right side of the diagram (all the labels are hot links to more info):
                      • butchone
                        • Aug 2009
                        • 147
                        Originally posted by Rocco
                        i have and had a 3B wiring loom working with AAN and ABY ECUs... all the same
                        i have a ABY wiring loom with AAN and ABY ECUs... works perfectly
                        3b ecu or loom cant be the same as it has a dizzy, and no loom to fire the coil packs. AAN, ABY are coil pack
                        • varia
                          • 821
                          • Current: United States
                          #27
                          would the stage 1 chip(s) from AAN work in the ABY?
                          Thank you
                          • prj
                            • Mar 2010
                            • 6308
                            Thank you
                            Sure.
                            • varia
                              • 821
                              #29
                              Originally posted by prj
                              Sure.
                              Thank you!
                              Reading back just what you guys wrote on this page:
                              If ABY ecu will have an AAN stgae 1 chip, the after run pump wont work, right?
                              Thank you again!
                              • prj
                                • Mar 2010
                                • 6308
                                Thank you!
                                Thank you again!
                                No, ECU has no effect on after run pump in either case, so everything will be fine.
