35R is a good turbo, and it will realistically give 600hp with 7A cams and 8.0:1 CR.
30R will give you 500 and a bit extra with 7A cams, but I would run that turbo with stock cams, to have full boost at 4100 RPM in 3rd. You can run this one with stock compression ratio, and it will still make 480hp or more without much lag.
HX35, at least the ones available, with a K26 #6 housing it makes about 460hp, and full boost is closer to 3900 rpm in 3rd gear. The compressor wheel on it is 78mm, so bigger than a 30R, and the turbine wheel is 60mm.
If you fit a K26 #8 housing, you can get to 500hp, but it will be the same as 30R in a 3rd gear pull, full boost at 4200 rpm or so.
Dyno pulls in 5th gear with heavy meth injection have little resemblance to real world performance. 3500 rpm full boost is fairytales, it will never happen in a real scenario except for high gear.
However, the Garrett BB turbos will be much faster in 1st and 2nd gear. Especially the 30R, which will reach full boost in 1st gear and spin the wheels. The HX35 will only reach full boost by end of 2nd gear, in 1st gear it will not make more than 1.4-1.5 bar, same like a K26/K27.
The Garrett turbo has better transient response, but it is more expensive, and if something goes wrong with it, you're basically screwed. The HX35 is a lot more durable and rebuildable, does not need any kind of restrictors, and can be run with oil cooling only.
Also, if you want less lag, buy a V8
The 35R is still a manageable turbo, but it is slower than a 30R on 2.2T until 3rd gear. Unless you use antilag of course, but you are not going to when driving on the street.
P.S.
Your car probably feels like crap, because your MAF housing has been changed, and I doubt that it is running correct timing in the entire range.
You can easily pick up 200 rpm in spool just from running correct ignition timing.
With cat cams you will have even more lag. Use 7A or Shrick.
The 35R is still a manageable turbo, but it is slower than a 30R on 2.2T until 3rd gear. Unless you use antilag of course, but you are not going to when driving on the street.P.S.
I think my cams needs to be adjusted, I have a adjustable cam sprocket on the exhaust, not on the intake side.
