3b20t intermitant miss at WOT.. ??
  • vertigone
    • Nov 2009
    • 253
    • Country: France
    #46
    AFAIK TOYOTA one "19102 02020" suits the same
    91' S2 3B Pearl White
    • stocious
      • Jul 2012
      • 838
      cheers and that was a good read too
      1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
      • stocious
        • Jul 2012
        • 838
        pics of progress, cleaning of engine bay.. i know its tatty. ill see what i can do .
          The metal charge pipe that goes to the throttle body polishes up really well
          • stocious
            • Jul 2012
            • 838
            scrubbing block 1st with brush and degreaser. loads of fun!! will do all the small bits too. id love to take engine out as im this far, but i dont have the cash at the mo to keep the ball rolling with a rebuild. at least i have it some way cleane/grime free for when i do
            • vertigone
              • Nov 2009
              • 253
              • Country: France
              #51
              If you can , change the little hose that goes to the water pipe/calorstat (above oil sensor) on this pic
              • stocious
                • Jul 2012
                • 838
                good idea.. gonna price it up as i was just going to order some bits as i read your post.. thanks.. only makes sense seeing where the thing is
                  Also check MFTS sensor connector for corrosion!
                  • stocious
                    • Jul 2012
                    • 838
                    what and where is the MTFS sensor. ?
                    • stocious
                      • Jul 2012
                      • 838
                      figures it out.. cheers will check that, and the others, found a good diagram on here
                      • stocious
                        • Jul 2012
                        • 838
                        spot on again, with the pcv pipes and this now.. cheers man.. corosion and broken wire !! what to do lol.. love old cars
                          Cool, that would have been a couple of weeks trying to figure out why you weren't getting the right boost..
                          • stocious
                            • Jul 2012
                            • 838
                            sure would of.. would this broken wire/corroded plug have any effect on the idle/startup of fueling at all.. between the pcv pipe split, and now this .. im curious to see if my smoking issue is related any/much.. in general for a car that i classed instantly as a rocket ship and was generally happy with overall condition/running for age, it must not have been at all!! can only get better cheers again
                            • stocious
                              • Jul 2012
                              • 838
                              less that a tenner for the plugs and wires to splice new plug in.. on order with the rest of the stuff .. friday maybe monday. not pushed happy its been adressed
                              • stocious
                                • Jul 2012
                                • 838
                                more cleaning in engine bay, nearly done now !! plus the knackerd knock sensor i found. will price tomorow.
