took bumper off for an intercooler inspection.. and found that the Mark H mod has allready been done!! possible ex forum members car ? haha . happy out knowing someone took the time previous
3b20t intermitant miss at WOT.. ??
some more progress with engine today..
getting ready for belt/pump. lined up both cam and crank and flywheel seems to be a "little" out. new belt will fix! forgot to take pic of mark h mod.
also is belt stretch common at all with 3b's as the backside of belt seems to have ripples, the low spots between the teeth of the belt. never seen this before, even on knackerd commercial's !!Last edited by stocious; 21 July 2012, 17:28.1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
You can't rely on the crankshaft marks at the front pulley, you have to do it by the zero mark on the flywheel, visible through the window in the bell housing
so do i get the line infront of the (O) to just line up with shoulder on box right ? ive done a belt on a 4 cyl 16v but was unable to see inspection hole on box ? have many of s2 now so i can see a lot now.1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
Some more progress today. mani off, dizzy cap and rotor also.. parts are taking forever to come.. nothings arived at either audi or my german parts supplier. had a day off to fit it all too..
not sure if the rotor that was init was the right one.. no bosch numbers.. and from what ive read the correct one is smaller across its face.. cant remember which rotor and hope i have the right one ordered ?1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
i have no pic but can anyone confirm to me that the ramp seen on inside top of butterfly valve in tb, is something to do with the breahter system!! bit vauge i know but there is an inlet just behined tb wich is part of pcv1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
Pretty sure that's the wrong rotor arm. Ramp on butterfly is to soften the initial throttle opening, so you don't kangaroo up the road when trying to pull away.
The web in the window should bisect the zero mark.Comment
Cheers Newsh, yeah the rotor is out by a long way
was wondering about the ramp, came to a theory that its there to stop the breather vap/oil being spread between all cylinders, as the back two run hotter/further from w/pump. but yours makes sense. thank you.
have manifold back on and running but i cant remember/find a hose that goes on to the t piece of rubber at back of head. below the three small vacum nipple's there is a larger one, i have no pipe for here. also below on the t piece like i said there is a provision for a pipe pointing slightly up and to the passenger side.. cant figure it out.. lol1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
Not sure what exactly you are talking about but assuming it is the PCV system, this info might help:have manifold back on and running but i cant remember/find a hose that goes on to the t piece of rubber at back of head. below the three small vacum nipple's there is a larger one, i have no pipe for here. also below on the t piece like i said there is a provision for a pipe pointing slightly up and to the passenger side.. cant figure it out.. lol
which came from clicking on the PCV label (all the labels are live):
3B PCV piping info:
Yes the larger one below the three small ones goes to the rubber T via a strange little rubber U shaped pipe and the one way valve, the carbon can valve plugs into this too.Comment
cheers lads, i think ive got it, will look when rain stops. 99% i have the pipe that green carbon canister valve connects to turned wrong way. then i will have the pipe to go to bung on mani and the green canister valve has reach to plug to outlet on the other side of it..1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
