now ive been replacing some old fuse i found and have changed the fuel pump relay, still no difference car suddenly dies on idle and it get worse when its hot, started to remove parts so i can check the hall sensor.
audi s2 aby...
The hallsensor is only there for the start up of the car IIRC... A faulty hall sensor shouldn´t stop the car once running, but will not start the car when sensor is hot.Comment
My ZX6R did this one year turned out to be valve clearance would start from cold no problem but would cut out once hot and not restart
have you got a healthy cylinder head try a compression test?
cheap check no parts required
dont know if it`s much use just a thought.Comment
when engine is on idle try to wiggle wires going to crank shaft sensor,also when engine is not running i would check connector to Crank shaft sensr for backed up pins etc.
as mentioned before cam position sensor is req.only to start engine.Comment
Yes thats my idea too, becuse it doesnt make any difference if the sensor is connected or not the car suddenly dies anyway.
Any idea is good, will do a comp test, but the car always starts directly after it has died. And it gets worse when the engine is hotter, and worse when you put your foot down
No i didnt becuse it didnt do any difference when i hotwired
The crank sensor is new and ive check the pins.Comment
G40 Cam Shaft Sensor Info including PNs and DIY
Not quite 100% true. A faulty G40 Cam Sensor will stop a running car even though it isn't supposed to (based on IrishS2's post to *this* forum):
General G40 Cam Sensor info
Sourced by clicking on the live labels in this diagram:
Yuo learn new stuff everyday!
Mines not that broken, its like à hill in my sensor. Gonna replace the sensor and camsprocket and hope thats the problem
I have no idea, bought the car as it was, all covers and so are on. I think that someone has tried to block the camsprocket or something becuse that just dont happen on its on.Comment
I posted a photo of your bent G40 shutter wheel on my home forum for ideas and their answer was just what you said: somebody has jammed a screwdriver (or the like) through one of the sprocket holes to block it when removing or tightening the cam sprocket bolt, instead of using the proper tool with the two round discs that fit into sprocket holes. (I can't find a photo of one but I have seen them)RS2'd 93 UrS4 5 spd sedan
yes probobly, i hope that this is the fault i am getting kind of tired of not finding any fault on the carI posted a photo of your bent G40 shutter wheel on my home forum for ideas and their answer was just what you said: somebody has jammed a screwdriver (or the like) through one of the sprocket holes to block it when removing or tightening the cam sprocket bolt, instead of using the proper tool with the two round discs that fit into sprocket holes. (I can't find a photo of one but I have seen them)
