Ive got some issuse with my s2, and i'm out of ideas now and is starting to think about aftermarket engine management. the car dies on idle and cuts while driving its like you turn the ignition on and off and it always start without any problems. ive got no fault codes in vagcom. It get worse when the car gets up to temprature
I have tested 2 diffrent boxes 3 diffrent chips, changed the mfts, knock sensors crankshaft positioners, pressurised the system. changed spark plugs, the throttle positioner. the air flow meter. new 115r coils
Any body got any idea ?
