Hi,
I am building up my S2 to match the RS2 spec; I will be using standard Audi RS2 parts like the Exhaust manifold, RS2 turbo etc.
I am aiming to match the standard performance of the RS2 to that of my S2 (ABY)
I am going to use the standard RS2 ECU but I may upgrade the software at a later date.
Should I upgrade to the RS2 exhaust cam? and what would you expect to happen to the performance if I just ran the car with the standard ABY Cams.
I understand the difference on paper 1 mm more lift with the stock and RS2 exhaust cam.
Should I consider the cam as a performance upgrade, is it necessary to do when upgrading to the RS2 performance.
What would the negatives be if I just left the standard ABY cams in the car and did the rest of the modification?
orsum
orsum
