Hopefully this thread's discussion might be of use to others as all of the stuff releatively straight forward if a little expensive, engine rebuild and the rest of the stuff is bolt on, so will suit the people who cannot fabricate stuff or rebuild an engine, and don't have the free time due to other life commitments, work, partner, children etc..
My question is which turbo to buy is based on the use detailed at the bottom of the post.
(To make it easier to grasp the two specs, imagine the path of the air being taken in through the grille to when leaves the tailpipe).
First spec for the car could be;
HKS Cone air , std air filter, Wagner RS2 Evo intercooler, Wagner front inlet manifold, std throttle body, ABY cams, ported head, std valves and valve springs, forged pistons and rods, 7a flywheel and Southbend clutch, all balanced, Wagner cast RS2 T3 flange exhaust manifold, GTX 3071 .63, matching injectors, 3" down pipe, 3"inch exhaust, no cats, Motronic ECU, Off the shelf chip options, or a custom map from Prj?
Second spec for the car could be;
RS2 air box, std air filter, Wagner RS2 Evo intercooler, Wagner front inlet manifold, std throttle body, ABY cams, ported head, std valves and valve springs, forged pistons and rods, 7a flywheel and Southbend clutch, all balanced, Wagner cast RS2 KKK flange exhaust manifold, KKK26/27 #6, matching injectors, 3" down pipe, 3"inch exhaust, no cats, Motronic ECU, Off the shelf chip options, or a custom map from Prj?
Boost from 1500 rpm is not possible like a modern Audi, so say more or less 100% boost from 3000 rpm up to say 6500, but normally change gear at 5000.
, as it's travelling quick enough compared to other traffic.
Car will never be tracked, used as daily, for short journeys around town, with the odd motorway include in some journeys, say 10 - 15 minutes worth as part of the journey. MPG will probably same with either spec. btw, what are people genuinely getting with either of the above specs and use ?
Just to confuse me further, what about Holset or any others, if suggesting them, please detail any fitting issues or anything else to be aware of as I need it to be more or less bolt on for both speed of completion, and secondly I can't do more than that, and I don't have any access to some of the amazing people on here.
All comments welcomed to allow the discussion to be fully fleshed out. Particularly keen to hear from people who have either turbo, and close to the car's proposed spec, thinking of Sonic and Ross, and a number of others.
Thanks very much in advance to all the people who take the time to make a comment.
, as it's travelling quick enough compared to other traffic.Car will never be tracked, used as daily, for short journeys around town, with the odd motorway include in some journeys, say 10 - 15 minutes worth as part of the journey. MPG will probably same with either spec. btw, what are people genuinely getting with either of the above specs and use ?
Having said that, each time I have learnt more about which turbo to pick, even if I seem to be taking forever to move forward.
and presumalbly others who are surfing the threads.
Hopefully it does.
and others, to step in with appropriate photos to further enhance the "brilliantness" of this I5 engine sticky.
