Strange engine behaviour
  • The Spanish
    • Nov 2003
    • 719
    Originally posted by Mihnea
    Rafael, this is ok, the MAF only has 5 connected pins inside of it, not more.
    BTW, how much boost are you running? can you measure boost in 3rd gear WOT from 1000 RPM and give me boost at 4k, 6k and 7k, and the RPM you're getting full boost at? Maybe do it in 4th too if it's safe to do it in Madrid...
    Cheers,
    Mihnea
    Hi Minhea,
    I still have not fitted the Boost Gauge, will begin all the work very soon. Lately I did not find time for anything.
    I am trying to solve my problems before fitting everything so I can be sure I did everything correct or faults appear because of the new instalation.
    In Madrid is even safe to do a run in 6th gear
    Cheers,
    Rafael
    94' RS2 Coupe TT (Twin Torsen )
    • Mihnea
      • 1288
      Rafael, are you running the ECU from me already or not???
      www.MRCTuning.com
      info@MRCTuning.com
      Workshop Directions
      • 4WheelDrifter
        • Oct 2004
        • 5773
        • Country: Devon
        Could it be a problem with the fuel breather or carbon canister/valve?
        SS
        • The Spanish
          • Nov 2003
          • 719
          No.
          I had a problem with the Exhaust Manifold.
          New one arriving next week. Then project will start.
          A couple of questions Minhea.
          What boost in PSI should I read in a 4th gear acceleration.
          Rafael
          • The Spanish
            • Nov 2003
            • 719
            #20
            Please explain more.
            Where are they, what they do?
            • 4WheelDrifter
              • Oct 2004
              • 5773
              • Country: Devon
              #21
              I’m not sure how the system works. I just know that when the canister valve came up as a fault on one of mine, there was a funny noise coming from the tank area. A bit like a buzzing noise. As if it was sucking bits of fuel and air. Have you tried pulling fault codes from the car? Just to check.
              SS
              • dkw_dude
                • 555
                • Country: Norway
                #22
                Carbon canister valve
                Leif-Helge
                -91 S2 VEMS and Comp Turbo
                -12 B** 530XD Touring "S2 parts transporter, and daily driver"
                • The Spanish
                  • Nov 2003
                  • 719
                  #23
                  http://s2central.net/ds_N80.html
                  Thanks.
                  If this in not working correctly would it be any fault code?
                  • 4WheelDrifter
                    • Oct 2004
                    • 5773
                    • Country: Devon
                    #24
                    Blink code 4343 i believe.
                    SS
                    • The Spanish
                      • Nov 2003
                      • 719
                      #25
                      Will check code on monday.
                      The valve is 100 Euro here so I expect is ok. Very expensive
                      • 4WheelDrifter
                        • Oct 2004
                        • 5773
                        • Country: Devon
                        #26
                        I just thought it might be worth checking.
                        SS
                        • The Spanish
                          • Nov 2003
                          • 719
                          #27
                          Clean the MAF and engine was flying today.
                          Dit around 100Km really pushing it and no problems whatsoever.
                          I still can hear the little buzz from behind when accelearating in first gear gently. Lets see if when I change the fuel pump if this disapears.
                          Thanks for the help
                            Cool
                            • 4WheelDrifter
                              • Oct 2004
                              • 5773
                              • Country: Devon
                              #29
                              Sweet!
                              SS
                              • S2sedan
                                • Aug 2004
                                • 189
                                #30
                                good to hear that !
                                S2 Limo sold !!!
                                M5 E34 with some mods in the garage
                                sorry, but much happeir now !
