Hi all,
I have a 51 row Mocal Oil cooler here. I guess it is worth sticking with the standard thermostat rather than a new sandwich plate. Or does anyone here suggest otherwise?
Can anyone tell me what the fittings are on the thermostat body?
Oil cooler is going to be situated low down in front of the main rad as it is a bit on the large size and I want to keep it low down to avoid any air lock issues.
Many thanks
Lee
PS, I know 51 row is excessive but I got it very very cheap (second hand but never used).
Many thanks
Lee
19 row cooler, a lot has changed with the car since then and I have moved the cooler down a lot lower, but all the fittings and sizes listed are the same.
