Whats causing oil in intake on rubuild turbo?
  • Mr G
    • Jun 2008
    • 196
    • Country: South Africa
    @quatrro-nick, thanx, yes I did clean the intercooler, used almost 2 bottles of thinners to clean out the IC. Will have to do it again
    So any help on which pipe to block off and to which pipe do I route the PCV on the below diagram?
    Thanx again
    • Mr G
      • Jun 2008
      • 196
      Sorry to which pipe do I attach the coke bottle to?
      • quattro-nick
        • Sep 2012
        • 1746
        • Country: Belgium
        disconnect pipe number 12 on intake tube and block off the hole
        put pipe 12 in a bottle
        TWINCHARGED power,zero lag
        AEM W/M injection
        • Mr G
          • Jun 2008
          • 196
          Thanx again quatrro-nick
          So to confirm (sorry) - pipe 12 will still be connected to the MAf- turbo pipe, but disconnected from the cam cover. Block off the hole on the cam cover and connect the bottle to pipe 12?
          • quattro-nick
            • Sep 2012
            • 1746
            • Country: Belgium
            #20
            no,disconnect pipe 12 from turbo intake and blok off the hole from turbo intake
            pipe 12 must still be connected with valvecover and put pipe 12 in a bottle so if you dont have oil no more in intake and at the same time you have oil in the bottle than there is a problem with your crankcase ventilation
            AEM W/M injection
            • Mr G
              • Jun 2008
              • 196
              #21
              Thank you sir - I'm glad I asked - much appreciated.
              I know what I'll be doing this week-end...
              • 220bhp
                • 2578
                • Home: United Kingdom
                #22
                I had this problem after rebuilding my rs2 turbo fitted to my 3b . It eventually it went away. We came to the conclusion that it was oil that had built up in the intercooler etc.
                caused by the failing turbo charger plus the extra pressure created by the reconditioned
                unit.
                • Mr G
                  • Jun 2008
                  • 196
                  #23
                  Last question on this ......I promise
                  How long should I/can I drive safely with "bottle" connected to to the valve cover - pipe 12 ?
                  • quattro-nick
                    • Sep 2012
                    • 1746
                    • Country: Belgium
                    #24
                    until the bottle is full
                    AEM W/M injection
                    • Mr G
                      • Jun 2008
                      • 196
                      #25
                      @quatrro-nick -I guess I walked into that one hey
                      Update - I did as suggested, see pics of my handy work , thanx to this here awesome forum
                      I take it, from the results/test the turbo is tired - no oil in the bottle, and a bit of oil on the "plug" used to block the turbo intake pipe.
                      My car now has +196 000kms, and has been driven pretty hard in my 6 years of ownership. Time to start saving the pennies I guess.
                      Thanx again for all the help I got here - all comments welcomed
