gt30
LWB Audi Sport Quattro projectComment
Yes,third gear !RED Mitsubishi Lancer Evolution VI TME nº 16 of 250
I don't remember it now
I'll try 5th gear /5500 rpm
I can't do more because my rev limiter is so gay at 6000 rpm.it looks a diesel my car
With wet tarmac I can't try anything with this car.
7000 rpm 6th gear? Are you crazy
You can't go faster than 30 milles/ hour in the streets !
Or do you want to be like hoffer76?
As I said before, due to the gearing on the car you will not be any quicker with the 0.63 A/R in pretty much any situation than you will be with 0.82 A/R.
The only situation is if you forget to shift gear. But from 4000 rpm there is no difference, and you can always get to 4000 rpm when the car is moving by shifting into first for example...
With the 0.63 A/R you will have to shift into first exactly the same way. Second will be still way too laggy for around town.
You still will get 2 bar in first gear with the 0.82 A/R...Comment
simplistically, the morre you stress the engine the more you will get real time, or more pure EGT readings, these are best IMO
quick blasts will not generate true engine EGT from what i have seen, Dmitri will probably back this up i presume.
EGT should be (rule of thumb) full load, 750-850 degrees C depending on fueling
Sound Dimitri il deffo go for .82 cheersAs I said before, due to the gearing on the car you will not be any quicker with the 0.63 A/R in pretty much any situation than you will be with 0.82 A/R.
I usually aim to have 850C post-turbo at the end of 5th gear.simplistically, the morre you stress the engine the more you will get real time, or more pure EGT readings, these are best IMO
This means 950-1000C turbine inlet temps, and this is as high as I go.
But yeah, that's why I was saying before, that you can make lots of power on the dyno if you just do a quick pull. All the components will be cool, IAT will be low and so on. When on the road and accelerating flat out through all the gears it will be a different story.
This is for example why meth injection is so good - it's like driving in winter all the time.Comment
