I'm a rather new S2 owner and don't know much about it. According to previous owner it should have 246 kW. I don't know what have been done with the engine to get this power. The problem is that when I hit the gas pedal then it takes 2-4 seconds when the turbo kicks in. All I have noticed is that the wastegate makes really loud noise during gear change.
What should I look for to see where the engine modifications have been done? For example where is the ECU hidden (3B)?
Can I reprogram the ECU (if it hasn't yet) without knowing what other modifications have been done?
Furthermore, no engine mods can be carried out on an S2 without appropriate reprogramming of the ECU, just because the ECU has safety features built-in and it won't tolerate increased boost or whatever, except if one tricks it with black boxes which are the worst thing one could do in order to tune his engine. My advice? Depending on where you are located, have the car inspected either by Paul or by someone who has enough knowledge of it, S2 repairs get very expeinsive if you don't know what and how to do it, especially in the quest for more HP. Where are you located BTW? It kind of helps if you fill in your profile
