Hi guys, long time no see! Moving house takes a bit of time dont it!
Well the problem with the car is when its first started, more from cold than warm although it does happen when warm, is the voltage stays at 10v untill revved up quite a bit..... Could this be an earth problem? Altenator? Not sure why it only raises the voltage when revved?
I think its more than likely the alternator but could do with second opinions guys!
