Electrical Fault
  • Beetie
    • Oct 2003
    • 1517
    Electrical Fault
    Hi guys, long time no see! Moving house takes a bit of time dont it!
    Well the problem with the car is when its first started, more from cold than warm although it does happen when warm, is the voltage stays at 10v untill revved up quite a bit..... Could this be an earth problem? Altenator? Not sure why it only raises the voltage when revved?
    I think its more than likely the alternator but could do with second opinions guys!
    Was a '93 3B, Dont ask now tho......
  • audiman
    • 4827
    Sounds like you have an alternator problem. After you have blipped the throttle, does it start charging OK??
    Tom C - www.rcmr.co.uk
    Audi UR Quattro
    Audi 100 C3 2.0 5 cyl 115ps
    Audi B5 RS4 645ps 911nm
    • caterpillar
      • 2480
      change the REG in the back of the alternator, only 2 small bolts.change to 14.7-15v,and check the lead conn at the batt
        Belt slip? Or could be the reg pack in the back of the alternator?
        • audiman
          • 4827
          sounds like a regulator problem to me.
          Why do you want 15V??? I cant see the reason behind this apart from making the lights a fraction brighter, and run the risk of destroying electronic components
          Audi UR Quattro
          • Beetie
            • Oct 2003
            • 1517
            Yeah my thought was the alternator too. God more money at the beast! Gotta fix the fuel leak thats just appeared now too!
              Beetie returns!, you must be outa beer!
              Hows she running now with the RS2 turbo?
              • Beetie
                • Oct 2003
                • 1517
                Yeah ran out of it last week! Its not too bad at the min although having been in the new house for a week and having to leave at 4am every morning is being a pain. Especially as it needs revving to get the volts up!
                Just needs mapping really, but theres a few more upgrades left to do yet, when ive got the dough.......
                Still faster than Bens though!
                • Erikb
                  • Jul 2004
                  • 648
                  I have the same problem, when I start the car it isnt charging the battery. When I rev the car to 1100 rpm the low voltage light goes out and it is charging the battery. I already have this from the moment I bought the car, it is still working.
                  Getting everything sorted out for my 5++ hp project
                  • porkkis
                    • 1994
                    Erik that's more like a feature, not fault. Don't worry.
