Lean? Who said anything about lean?
2413 (Blink Fault Code), 00561 VAG1551/2 Fault Code Number
Mixture Adjustment,
Adaptation limit exceeded, Adaptation limit not reached, Leakage in exhaust system before 3 Way catalytic converters, Incorrect signal for Mass Air Flow Sensor, Spark plugs, ignition coil(s), or Ignition Coil Power output stage malfunctioning
Symptom: Rich mixture, increased fuel consumption
Mixture Adjustment,
What are the units of "IPW"?
