Noisy PAS
  • Drummer87
    • Oct 2009
    • 1644
    • Home: United Kingdom Current: Scotland
    Noisy PAS
    Just been outside to start car up after its been laid up for winter.
    And I'm greeted by a noisy pas pump. Is this common with our cars?? Would tightening the belt help or the pump seen better days??
  • Louie C
    • Jun 2012
    • 288
    Yeah my new Avant makes a bit of a fart like noise when turning the wheel left at low speed, I take it this is curable?
    • audinut
      • Jul 2009
      • 2195
      pump rebuilds well documented on here although youl have to be brave!
      NOT a car dealer! just an S2/RS2 enthusiast
      • Drummer87
        • Oct 2009
        • 1644
        Hmmm mines on idle could be cold. Sounded alright after a 15min warm up
        • QuattroFever
          • May 2006
          • 1360
          I used to get a clatter/rattle from my old one when cold
          Volcano ABY coupe
          Ant
          • nesshead6
            • Apr 2009
            • 598
            Mine also makes a groaning noise only when turning left..
            • LHD_Kid
              • May 2006
              • 3696
              Mine too, although it seems to happen more when going uphill, when you have to add a small amount of throttle. Actually, you can provoke the groan by accelerating very gently and turning left slightly... never fails...
                WD40 + belt = hapiness
                • Drummer87
                  • Oct 2009
                  • 1644
                  I read wd40 you shouldn't spray as it eats into the belt over time shorting the life span
                    Can't say I've had any issues in 8 years...
                    • stocious
                      • Jul 2012
                      • 838
                      it also eats whishbone bushings ect.
                      1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
                      • johne
                        • Apr 2007
                        • 1405
                        My pump has been noisy for 140,000 miles, especially when cold but is still going strong.
                        John
                        • Monkeymagic
                          • Mar 2012
                          • 3419
                          probably just needed a run to let the oil thin down and lubricate the bits and pieces. Wouldn't worry
                          • Tonybolony
                            • Dec 2011
                            • 636
                            I changed the PAS oil, and it made quite a difference to the pump noise when cold, also gave more braking and steering assistance. (I'm sure it's not my imagination)
                            I also tried WD40 on the belt,(and it worked) careful to keep it away from the cam belt- not sure I would want wd on that!!
                            • gadget6970
                              • Jan 2010
                              • 87
                              steering pump
                              I had a coupe for 12 years and in the winter pump was noisy,and summer it was quite. +sprayed with wd40 which works.Always said i wanted to replace when it died but it lasted the 12 years i owned it with no operational issues.changing steering fluid helps too.
